SUBCHAPTER E. GENERAL LIGHTING REQUIREMENTS FOR VEHICLES
§ 547.321. HEADLAMPS REQUIRED. (a) A motor vehicle
shall be equipped with at least two headlamps.
(b) At least one headlamp shall be mounted on each side of
the front of the vehicle.
(c) Each headlamp shall be mounted at a height from 24 to 54
inches.
Acts 1995, 74th Leg., ch. 165, § 1, eff. Sept. 1, 1995.
§ 547.3215. USE OF FEDERAL STANDARD. Unless
specifically prohibited by this chapter, lighting, reflective
devices, and associated equipment on a vehicle or motor vehicle
must comply with:
(1) the current federal standards in 49 C.F.R. Section
571.108; or
(2) the federal standards in that section in effect,
if any, at the time the vehicle or motor vehicle was manufactured.
Added by Acts 1997, 75th Leg., ch. 324, § 1, eff. Sept. 1, 1997.
§ 547.322. TAILLAMPS REQUIRED. (a) Except as provided
by Subsection (b), a motor vehicle, trailer, semitrailer, pole
trailer, or vehicle that is towed at the end of a combination of
vehicles shall be equipped with at least two taillamps.
(b) A passenger car or truck that was manufactured or
assembled before the model year 1960 shall be equipped with at least
one taillamp.
(c) Taillamps shall be mounted on the rear of the vehicle:
(1) at a height from 15 to 72 inches; and
(2) at the same level and spaced as widely apart as
practicable if a vehicle is equipped with more than one lamp.
(d) A taillamp shall emit a red light plainly visible at a
distance of 1,000 feet from the rear of the vehicle.
(e) If vehicles are traveling in combination, only the
taillamps on the rearmost vehicle are required to emit a light for
the distance specified in Subsection (d).
(f) A taillamp or a separate lamp shall be constructed and
mounted to emit a white light that:
(1) illuminates the rear license plate; and
(2) makes the plate clearly legible at a distance of 50
feet from the rear.
(g) A taillamp, including a separate lamp used to illuminate
a rear license plate, must emit a light when a headlamp or auxiliary
driving lamp is lighted.
§ 547.323. STOPLAMPS REQUIRED. (a) Except as provided
by Subsection (b), a motor vehicle, trailer, semitrailer, or pole
trailer shall be equipped with at least two stoplamps.
(b) A passenger car manufactured or assembled before the
model year 1960 shall be equipped with at least one stoplamp.
(c) A stoplamp shall be mounted on the rear of the vehicle.
(d) A stoplamp shall emit a red or amber light, or a color
between red and amber, that is:
(1) visible in normal sunlight at a distance of at
least 300 feet from the rear of the vehicle; and
(2) displayed when the vehicle service brake is
applied.
stoplamps on the rearmost vehicle are required to emit a light for
(f) A stoplamp may be included as a part of another rear
lamp.
§ 547.325. REFLECTORS REQUIRED. (a) Except as
provided by Subchapter F, a motor vehicle, trailer, semitrailer, or
pole trailer shall be equipped with at least two red reflectors on
the rear of the vehicle. A red reflector may be included as a part
of a taillamp
(b) A reflector shall be:
(1) mounted at a height from 15 to 60 inches; and
(2) visible at night at all distances:
(A) from 100 to 600 feet when directly in front of
lawful lower beams of headlamps; or
(B) from 100 to 350 feet when directly in front of
lawful upper beams of headlamps if the vehicle was manufactured or
assembled before January 1, 1972.
