Couple questions....replacing shocks, need ball joints/ control arms....
1335 0
Okay guys my plan is as follows.
I will be buying the bilstein 5100 ride height adjustable shocks for my truck.
I also need to replace my ball joints and possibly my front hubs if the bearings are shot like i think they may be. My question is:
What would you guys suggest as far as a lift kit? I only want to at a minimum level the truck off, and at a maximum lift the truck as hi as possible without changing the whole suspension. What do you guys recommend as far as the max lift for stockcomponents? Also since I need new ball joints should I just look into a suspension kit? How hard are the ball joints to remove and replace? And should I just get new control arms?
I will thank you guys in advance since everyone here has always been extremely helpful .
Thanks All!!
Jason
