Fixed my crank no start issue where the fuel pump was not engaging. Ipdm fuel pump relay shorted out and failed, therefor it wasn't sending current to the chassis harness. Put a relay on the trailer tow socket and rearrange the wire connecting the pins on the chassis harness so the good wires from the relay were connected to the fuel pump instead of the trailer tow socket. You can do this a bunch of way I just used that placement for a quicker fix.
Sent from my SCH-I545 using Tapatalk
