My son has 4” CTS Performance Suspension lift on his 2009 titan. For some reason it is making a squeaking noise coming from the driver’s side of the truck. I used a can of WD-40 to locate where the squeak was coming from. My son was pushing the front end up and down while I started spraying the lube starting at the lower end of the suspension lift. The squeak stopped after spraying the top portion of the lift. The spray lube worked for about a week. Any have this kind of problem before? What would cause the suspension to squeak?
