I have an 04 CC I have had a knocking noise coming from the center console for quite some time. I thought I had fixed it with the ground wire fix in other threads. When it got cold it came back.
Hppens when cold and warming up.
RPM's don't match or change noise.
No ryhme or reason no pattern of noise.
Sounds like tapping the handle of screw driver on table while holding the metal part.
Happens driving or parked. Drive, Reverse, Nuetral.
Can't find a way to make it stop.
Turning Ac or heat makes no change.
I could sure use some help. I don't have the cash to go to dealer unless I can figure out what needs to be done first. I am guessing it might be a control valve or something. I just don't want to spend a G letting them replace parts until they find the problem.
Thanks in Advance. My many thanks to everyone on this post, it has given me the confidence I didn't have to open the hood and get dirty.:cheers:
