Maybe you can use it for either the high or low beam depending on which bulb you use? Are the holes the same for highs and lows?
Kind of, so the low beams and high beams take one of each? Then I guess it could be used in either one? I know I sound dumb but this is all knew to me, I put all my money into performance stuff usually. LOLIt says that because the housing takes one of each bulb to make the high and low beams. It is just showing you the two bulbs required to fill that housing. Hope this helps.
wow people actually run their low beams brighter?? Good Lord, idiots!!
