On page 40 of the Titan / Armada document, it states:
"Whenever a tire/transmitter replacement, BCM replacement or tire rotation is performed, the Transmitter ID registration procedure must be performed to identify the location of all transmitters. This procedure requires the Consult-II scan tool with the Consult-II Converter, plus the transmitter Activation tool J-45395. The transmitter activation tool is also required for transmitter wake-up"
So the dealer has to rotate the tires if you have the nav system to know the location of each tire?
What kind of BS is this?
