With this mini pack, I believe you remove the overload spring. What does this for payload and towing? Would it be real bad, or barely noticable.
Big ride improvement, and sags less when loading a trailer or bikes in the back. Make sure you're replacing the awful factory shocks also...
I tow a small trailer with 2 dirt bikes and the truck used to ride just above the overload spring. Every bump dip was felt like it was bottoming. Real spine tingeling...
Now(with new shocks) it rides higher and uses the travel smoothly.
Short story - Better
The overload spring is not used with the Deavers. If you tow and experience too much sag, you can get a set of Air Lift air bags. They will prevent any further sag.
