I debadged my Titan a couple of weeks ago. I used a heat gun but a blow dryer will do. The emblems are attached with an automotive adhesive tape. Heat the emblem so the adhesive is flexible, be careful not to apply too much heat. I used a bondo spreader to lift the emblems off the truck then simply peeled off the adhesive, with a little heat when needed. I then cleaned the surface with naptha and applied a coat of wax. I took off ALL the tailgate and body emblems and the OFF ROAD decals. I took off the taligate NISSAN emblem then decided I liked it so I put it back on. You will need to remove the tailgate panel screws, remove the panel, remove the inspection cover (double sided tape) and then remove the emblem. I was surprised that I liked it but with all the other junk off the tailgate it looks sharp to me.
