1 - 20 of 30 Posts
WHAT DO YALL THINK?
i had to do it with a dremel,i cut out the hole smaller then the s/g then filed it down little be little till i got it to fit snug. might glue it on the back but i do not think it is needed.
Nice, clean installation. Looks good!
Looks good, the cut could have been a little cleaner but over nice placement.
i know it was like 10 at night i plan on gettin a black groment to go around it
I think I need one of those gizmos for my Titan.
Nice job!!
Discussion Starter · #8 ·
Thanks Guys. Was Not Hard To Do At All
i did mine in the same place, the same way. its a perfect spot to mount however, for me atleast, its not the best angle for the driver. its cool though i just lean to the right.
that looks pretty tight, nicely done.........that does 0-60 times? 1/4 mile times?
No, it does fuel economy, distance to empty, and much more. I love having mine.
Discussion Starter · #14 ·
that's a good spot. but my rear window roll down switch is there.
holy old thread batman. but was the scan gauge wire harness long enough to work up there
Probably not as is but you can extend it with an ethernet cable.
I know at one point if you bought the SG2 with the Blendmount, it came with an extension cable. Maybe it's also available separately, check with Blendmount.
thanks problem solved picking mine up next week
1 - 20 of 30 Posts
