Looks good man....now get you as$ to the gas station and get a fill up. :eyebrow:
i just sent you a pmwhat did you do to the head light i want to do that
Both my stock 06 headlights are crying and full of tears, so I may get some EBay specials and send them to have cleaned up and modded w/ red white and blue lighting...if you want i can do the headlight mod for you for about $250, the kit that i found is about a $100 dollars and to get them on requires some drilling and custom work. The kit i have changes colors and the size is 80mm but they sell a one color kit that is 100mm that you can get in about any color.
not to be off topic but did you get your lift at planet pick up, i saw a pic there of a nice looking white lifted T and they said they only due fab lifts? i'm in San Antonio as well but haven't seen you around. i'm thinking about doing this LED mod or maybe having you do it. pm on how much you would chargeto change the leds out you need two different sizes of bulbs which need to be used in different parts of the truck. below is a list of where the seperate leds types with the part that needs to correspond to that led.
PLCC-2 1210 LED(square led)- gauge clusters, odometer, screen display for radio, and havent done it but maybe display for A/C
1206 SMD led(small rectangle)- this is needed for the buttons for radio, door controls, and for the A/C buttons(that part is really hard to do. there is two lights in the inside of the three buttons, one which looks like the small led which is easy to change but the second looks like a bulb that requires a resistor to be soldered on as well)
