difference in trim levels
1 reading
6.8K views 5 replies 3 participants last post by  busemans
Hey weird question,
I recently inherited a 2004 Nissan Titan and I am lost on what trim level it is. I know the levels are xe, se and le. I don't see a trim on the outside like a lot of titans I see. It has no trim marking that I can tell. I believe its the entry level xe. It does not have a sunroof or adjustable pedals. It is a crew cab 5 1/2 foot bed. It has cloth seats and on the vin plate on the door jam it says the original tire size is p245/75r17. I did observe it has stock rims on it with 275/65R19 tires on it though. I am pretty lost on how to find out how to determine the trim levels. I would appreciate any help, I am new to the Nissan truck world.
#2 ·
#3 ·
welcome to the site!!
type your vin into this parts page and it will give you the info on your truck.
Genuine OEM Nissan Parts and Accessories Online - Nissan Parts Deal
it will be under the vin once you hit enter. mine says this: Crew Cab; 8 Cyl 5.6L; Four-Wheel Drive/Mid Wheel Base; SV/Comf; 7 and mine is indeed an SV
Sweet Man, This worked perfectly for me, It is an XE like I thought. I really appreciate it, I was struggling to find good information on it.
#4 ·
no problem
#6 ·
mine does say the same, i just cut it off when copying.
Crew Cab; 8 Cyl 5.6L; Four-Wheel Drive/Mid Wheel Base; SV/Comf; 7-Speed Automatic Transmission; Standard 150
maybe standard 150 is the half ton designator? we need some other to try it out and see what they get on their description
Reactions: basketcase
