I just changed the rear differential oil for the first time. It really was a piece of cake. I installed the axle breather mod and decided to just go ahead and change the oil too. I drove about 10 miles so as to heat the oil a bit and get some of the metal shavings into the oil.
The OEM check valve seemed to be functioning properly. There was no sound of air streaming in or out of the axle when I removed the valve. Other than smelling as bad as everyone says it does, the oil, otherwise, looked good. No signs of water intrusion into the axle. There were some metal shavings on the drain plug, but not much. The oil was clear enough for me to be able to see the bottom of the drain pan. The oil had about 20k miles on it. This is my third axle, the first two having been replaced under warranty for making lots of noise at speed. I take it the clear oil is a good sign? I was half-expecting the milkshake from many of the posts here.
I filled the pumpkin with Mobil-1 75w-140, so I am hoping I am good to go for a while. Was there anything else I needed to be on the lookout for?
