Hey guys,
Can the dim orange overhead console light be changed color?
Thanks
Thanks
Is it the same bulb type as the dome lights? Door lights? Or is it completely different?Yes, you can swap it out for an LED bulb and put any color in it that you want. I also took a drill and made the hole a touch bigger to allow more light out. Its called the "mood light" do a search on here and you will see. Center console needs to come down to replace it. Takes about 15 minutes to do it.
