You don't need to go into the doors for the door lock functions. There are two empty pins at the BCM in the 40 pin white plug. Counting from the opposite side of the CAN wires, in the same row pin 7 is unlock (needs a double pulse) and pin 8 is lock. You have to use a diode in each hole, stripe toward the connector.
