Posted in some other "why does truck randomly overheat threads," LSS I could never find symbiosis with my Stillen 3 row.
It might not have been their fault. Kinda.
TL;DR HERE'S MY LESSON LEARNED
- Run the stock cooling system for less headache
-- Yes, even though the stock rad plastic tanks (mostly lower) sometimes crack.
I didn't have time to fool with it again, so $1200 for a shop to replace:
- OEM rad & shroud*
- water pump**
- clutch fan***
- AC recharge/evacuate
And now I am over the moon happy with the truck again. Finally.
Along with my nearly new aux fan, my whole cooling system has been replaced. (Actually, aside from starter, power steering, in-cabin motors/electrical, and motor/transmission/transfer case, rest of truck is new last 10K miles, LOL. Cool!)
I now have confidence in my cooling system again. 95* weather yesterday, towing, idling, A/C keeping wifey cool, no problems. Big relief.
*** THIS IS MY 3RD CLUTCH FAN
I ordered and replaced my original with a one from Rock Auto ~ 5K miles ago. It was junk from the get go. I had my doubts when I first installed it (was easy to turn by hand when hot) but at the time lived somewhere cold and thought...well, it's new, what are the odds it's bad? (It was a bad unit.)
Also, with my back-to-stock cooling system, the truck roar has returned! OMG I forgot what it was supposed to sound like. YES (anyone on the fence) if your clutch fan doesn't make you sound like a semi-truck, it's likely bad. So much air-suckage now.
** WHY THE WATER PUMP
It was just an additional $215 parts and labor and I didn't want any more excuses or left-turned over rocks. My idea, not the shop's.
* AND ON THE FAN SHROUD
Fellas, this thing is needed for hot weather. I rolled the dice, didn't work.
A MAJOR PROBLEM WITH THE $500 SITLLEN RAD IS THAT THE SHROUD FITTING IS TERRIBLE and causes contact with the clutch fan. Dudes have done the swap and busted their clutch fan to shreds just pulling out of the driveway.
WAS USER ERROR INVOLVED?
Maybe. I couldn't get the shroud to fit (burned up 5 hours trying when I originally installed the Stillen rad).
I also never could get the bubbles all the way out of the cooling system. Multiple burping sessions. Every time I thought THAT'S IT GOT 'EM ALL I'd overheat again (in FL summer weather) a week later. YMMV
Anyway, this is a long way of saying...
... anyone in the market for a barely-used 3-Row Stillen? :big_grin:
- OEM rad & shroud*
- water pump**
- clutch fan***
