Nice!
You should stop by and say hello!
Not sure what you're talking about 2 shafts and a fitting. It should just be a single drive shaft with a slip yoke. You probably dont have any grease in the slip yoke. Throw some in there and see if it still has that flex with a click. If it doesnt tighten up with grease, you need a new slip yoke and stub. For the play in the seal, is the seal leaking?06 KC 4x4 No Fear from dealership...hoping my problem is as simple as this...I have a "double" shaft -looks like 2 shafts connected by a fitting- I'm not sure if yours are the same... a few months ago after a trip to the dunes I had to replace all u-joints and trany mount. I recently had to go down there and re tighten my trany mount because I had what appeared to be a front suspension clunk on accelerated turns... while I was down there I discovered significant play in my transfer case seal and my shaft was flexing with a click in the fitting that connected my combination shaft... thoughts? New shaft and seal? Or bigger issue inside?
When you put grease in it, make sure you line it up back the same way. Being out of phase will throw off the balance so mark it before you pull it. If the front output shaft on the transfer case has play, that bearing is shot. It should be nice and tight when you move the yoke.Yea it's the slip yoke. .wasn't sure what it was called... the bearing is not leaking at this point... should I pay attention to it at this point
