ok bro you have 2 coolers, one is the radiator then it exits and goes into the cooler that you saw in front of the rad. from there it goes to the tranny.
if you get under your truck and remove the plate youll see the 2 lines that go in and out of the tranny. the one facing the driver side is the exhaust line and the one facing the passenger side is the intake line.
hope it helps
hope it helps
