I believe only if you lift or lower your current height, (like for someone with height adjustable coilovers that just has to crank them up or down a turn or two), and then only a simply Toe alignment, which you can do with a measuring tape and adjusting the tie rods. There are instructions around here somewhere. Looks easy and will save you ... I mean them $80.
