I am wondering if a Airraid throttle body spacer will fit with the K&N Generation II FIPK airintake ststem.....any help would be much appriciated.
yes i currently have the K&N intake installed. got it today :rollingsm. I do not think there is an inch of space befor it runs into the plastic from the fan housing.....is it safe to cut the intake tube slightly??? and if so will i loose power from the intake?
I have the K&N and a TB spacer. I had to modify the K&N to make it fit. I cut about 1" off the intake tube then had to reform the end with a heat gun to create a stop bead for the rubber sleeve to hold on to. It was a pain in the butt.
