Not sure if you can get the inner panel off enough with the door shut to release it, but that's the first option I'd try.
Did the plastic handle on the outside break? If so just break it the rest of the way and pull it out. Should be able to pull the latch up by hand if it's open to the outside.
It pops off, but you have to undo a Torx security bolt from inside the door. Can't do that unless you open it unfortunately.
