1 - 10 of 10 Posts
How do you replace this black wrap on the door pillars? With just regular wrap they use to wrap roof and hoods? What's underneath same paint as the rest of the truck? It's faded, chipping and cracking..
Some have removed it to find paint that matches the rest of the truck. Others have found a matte finish paint, similar to primer. Odds are, whichever you want it to be, it will be the other...
If you don't want it colormatched, you can remove it, tape it off, and just rattlecan it black or whatever color you want. You can bedline it black too. Putting new wrap on there... I don't believe in all the years I've been here that I have seen anyone remove it and try to put the same thing back. Up to you... :dunno:
Could just tape off the windows and such and bedline it. Probably easiest solution.
I removed mine last year. It was only on the front door. The rear was black painted. Under the factory vinyl was the same paint as the rest of the truck. I left it like that for about a month and decided I didn't like it. So I wrapped it again with flat black I got from my company's vinyl shop.
Yeah that's what I'm afraid of it won't be matched. But where the big Crack is it looks like primer kinda paint but where there is a chip it looks paint matched..so no one takes it off and really wrap it? I think that be the simplest and cleanest look especially since itll match the gloss look of the tinted window. Do you have pictures of yours if its rattle canned or bedlined?
Discussion Starter #6
Was it hard to remove and re wrap? Was there a huge difference in the shine of the paint from the rest of the truck? From your profile picture it looks like we got the same color.
Just noticed this guy is local to me. He could bring his truck by and I could bless it for him.
Discussion Starter #9
We do. And it wasn't too bad. They did put the rubber trim over the vinyl though so you have to pull the trim a little to get to it all. The adhesive left on the paint cleaned up with some goof off. It just looked weird to me after a while.
1 - 10 of 10 Posts
