1 - 20 of 20 Posts
Nice. Welcome to the DT club.
They sure look purdy!!
congrats Ive been having mine for 6 months now and still havent installed them. Should have time this christmas break though, college is time consuming. lol
Discussion Starter · #10 ·
I ordered these parts from nissan parts dept.
2x Exhaust metal gaskets (part #14036-7S001)
4x Manifold to collector stud bolts (part #14064-JG30B)
2x Exhaust collector o-ring gaskets (part #20691-30P00)
All for $59.52 shipped.
Here are pics of all the parts and a pic of the new doug thorley collector bolts compared to the factory studs.
Also the doug thorley studs put into the collector.
hope these help!
hope these help!
Funny thing is, I have header gaskets, studs, nutz, metal o-ring gaskets in my tool box. Don't ask cause I wont be telling why I have extras.
I know what you mean when you say college is time consuming, especially when finals are around which is coming up....:bangit:
The only thing I ran into on mine was the bolts at the collector connecting to the b-pipe.
From the picture you can see the bolts which came with the headers where not threaded down far enough. I had to pick up new bolts and nutz.
Couldn't you have just added like two washers???
hope these help!
I bought flange gaskets for collector to B pipe in addition to the O-rings. Are the flange gaskets needed?
I just received the headers and the collector bolts look fine to me. Same as your pic.
von made me some B-pipes with custom bend pipe with MF cats & flanges and I have JBA cat-back. I think I am getting pretty close to set once I get the gasket situation straight.
I have the metal Nissan OEM head to exhaust manifold gaskets.
I have the header collector to B Pipe metal O-rings.
Questions:
Do you use a metal flange gasket between the collector flange and the B-Pipe flange?
Do you use a metal flange gasket between the aft end of the B-Pipe and the JBA cat-back flange?
Questions:
Your going to need the metal gaskets before and after the b-pipes. You dont need the metal O-ring.
after installing long tubes, do you need to reprogram the computer?
1 - 20 of 20 Posts
