1 - 20 of 50 Posts
I have a few questons about the service manual that you can download.
1) How long does it take to download the manual useing a cable modem?
2) Can you burn it to CD after you download it?
3) Is it the full version or is it a "abbreviated" version?
4) Do you like it? Is it worth the money?
5) What is the web address to download it?
Took me about 30 minutes on a cable modem. There are 48 files and you have to do each one individually.
If you have a CD burner, you can. The files are all PDF (Adobe Acrobat). Once they are on your PC, what you do with them is your choice.
Well, not having seen a 'real paper' version, I would have to assume that this is the same thing.
I was able to find out where some of the wires I needed to tap into were routed. I guess it was worth $20.00
Downloadable PDF manuals
There are about forty individual files, consisting of a few thousand pages with many sections containing over 500 pages. Manual is about 92MB, quite large for downloading over a 52k modem.
Excellent resource.
There is also a manual for the navigation system.
It is a great deal for $20.00. They have it listed for $210 on a CD. I guess they forgot about the "Save a copy" button in Acrobat or something.
pistonpete said:
Maybe I am not in the right area or something but all I see offered is the manual on CD for $210. I don't see a download for $20 :eeeek:
You do a one day online subscription for $20 and then you do a search for all publications for the Titan. That will give you the option to do an online view of the service manual. Then you have to view it with Acrobat, and individually save each section of the manual, as summarized in the Quick Reference Index. When you get done, you will have these files:
ACC.pdf
ACS.pdf
AP.pdf
AT.pdf
AV.pdf
BCS.pdf
BL.pdf
BR.pdf
BRC.pdf
CO.pdf
DI.pdf
EC.pdf
EI.pdf
EM.pdf
EX.pdf
FAX.pdf
FFD.pdf
FL.pdf
FSU.pdf
fwd.pdf
GI.pdf
GW.pdf
IDX.pdf
IP.pdf
LAN.pdf
LT.pdf
LU.pdf
MA.pdf
MTC.pdf
PB.pdf
PG.pdf
PR.pdf
PS.pdf
RAX.pdf
RF.pdf
RFD.pdf
RSU.pdf
SB.pdf
SC.pdf
SE.pdf
SRS.pdf
TF.pdf
WT.pdf
WW.pdf
You simply CANNOT beat Nissan's $20 option... I downloaded the service manual for the Titan, which cannot just be DOWNLOADED, but you have to choose to view it online and in Acrobat Reader save a copy of each section to your local disk. I also, within the same day, downloaded the service manual for my girlfriend's 2002 Altima and my friend's 2003 Murano. :)
I best do this tonight before Nissan reads this thread.
hey there, I am trying to do the same as above, but there is no file name for the pdf file. it will not let me save it. Is it because I am using the free reader?
Thanks alot!
I used version 6, loaded the table of contents and selected each chapter from there. After each was downloaded, I went back to the TOC and just selected the nex tone. The TOC is linked to all the chapters which makes it real easy to download the chapters.
it's still there
bvstone1 said:
Couldn't find where to sign up for the $20/day and view the manual online. Thinks they took it off?
Once you sign in with your free registration, then look under the select catalogue and pick online subscriptions. The one day is still there.
titan711 said:
is it legal to sell these manuals online?
No it is not.
Also, advertising that it is available here will get you banned for a month.
1 - 20 of 50 Posts
