Yes you are correct..there are rear air vents in the center console but, there is also on under each seat.titanized said:With the Capt Chairs the rear vents are in the center console. Is it the air ducts that feed the rear air vents in the center console??
You must be right because i see the actual vents under the seats. Hmm...that can't be a good place to locate the vents' tubings, right at the the feet (if you sit with your seat all the way back). Thxbg478 said:If you guys look under the carpet under the seat you will see a heat/AC vent for the rear passengers. You are actually crushing the plastic vent.
