Driver side rubs passenger side don't?????
1036 Views 3 Replies 2 Participants Last post by  NorCal 4x4
left turn out side edge of drivers tire rubs middle rear of front fender. cant even make a full left turn without it hitting..right side clears with maybe 1/2 to 3/4 inch..any suggestions..truck tracks straight and steering wheel dosen't wobble..so im assuming alignment is straight. had lift for 3 weeks and am stumpped. did pinch weld mod but that was not even a issue rims have a -12 off set..
Caster alignment. The cam bolts used for adjusting camber are used for caster too. Since you have an '05 you have them, but they can get rusted too much to adjust. You can instead do the pinch weld mod, (see link in my sig). If it still rubs you need to cut more, and -12 mm offset on a 9" rim is the usual cause of rubbing at the pinch weld.
"You can instead do the pinch weld mod, (see link in my sig). If it still rubs you need to cut more"
I did the pinch weld mod...it rubs in the center of my fender, no where near the pinch weld but only on driver side..im going back to alignment shop today to have it looked at
Do you mean behind the mud guard, (if you have one)? I had to trim there too, as I show in the pic in the link, but on both sides. If you can get your caster changed that would be best, but it needs to stay within the range spec'd.
