Some have posted it was a TSB I think. Mine do it to this day. Not a big deal to me. If my truck were still under warranty i would go have it looked at. It's a relay or something. You aren't alone in this dept. Several have the same issue.
Mine do the same thing. From what I understand all later model Titans do this. It is a safety mechanism that retracts the window if something is caught in it. Mine started doing this after I installed my internally mounted vent shades. I found out it was because the vent shade makes the track a little tighter and hence the sensor thinks something is stuck in the way so it lowers the window. I have been told there is no sensitivity adjustment for this feature. Luckily mine only have this issue when it's cold. I guess it's because of the less pliable rubber in the track due to the cold. Oh well, I still love my Titan.Kortiz said:So it's been cold the last few weeks. Anywhere from 3-15 degrees anytime I've been out driving. Last week, my window was frozen shut.
A couple days later I needed to lower the window down and it worked no problem, however when I lifted the window back it went all the way up and then 3 or 4 inches down before the mechanism stopped.
So my window wouldn't stay shut using the 1 touch open/close. When I babied it to the top, I could close it, but I need to get this fixed so that I'm not playing with my window every time I need to open it.
Has anybody else had this issue? Is it because it's cold or is my window fubar'd and need serviced?
