1 - 2 of 2 Posts
Well last week my power window on my o4 le, driver door stopped working, all other windows open fine. i found a used door switch assembly on ebay and replace the swith and it did not fix the problem, so i doubt the switch is the issue as highly unlikely 2 switches have the same issue, so what parts are left to look at before i shell out $150+ dollars for a new window motor? is there a fuse for each window i can check? what others parts can fail to cause a window to become inop?
My 2002 Ford Exploder had a similar issue. Turns out it was the power window motor. Unfortunately the regulator and motor were not sold separately so I had to purchase them both.
That might be your issue.
1 - 2 of 2 Posts
