Lately the motor that moves the seat forward and backward has started working intermittently. Poked around with it for a bit...lubing the threaded rods, etc. with no success. Yesterday I noticed that the motor (located directly under the front of the seat) actually rolls a bit when the motor is activated. Again messing around with it I figured out that when it is not working I can reach under and pull up on the motor and it takes off (starts working).
Anyone else run into this? Do you think there is a mounting issue, linkage/track/threaded rod issue or should the motor be replaced?
