Hello, I recently purchased a 2007 Nissan Titan King Cab. I purchased a head unit that had a back up camera and wired the head unit to the driver's side back up light. (The head unit needed a wire to be powered when the truck was in reverse to tell it to turn on the camera). This worked fine for a couple months. A few weeks ago the driver's side reverse light stopped working along with the back-up camera. (The passenger side still works). Fuse under the hood is good. When the truck is in reverse the driver's side factory wiring (at the lamp) has no power. Passenger side reverse light works fine.
Nothing wrong with the splice. It is the first thing I checked. There is no power in the factory wire (for the reverse lamp) on the driver's side of the vehicle when the car is in reverse. The passenger side works fine.
What method was used for the tap? If the 'usual' U-shaped metal guillotine that slices through the insulation to make contact with the center wire, I would remain unconvinced that the tap is OK. In other words, anything less than strip back the insulation, solder the tap wire and wrap with insulating tape would be questionable.
Check all the fuses in the fuse blocks for a blown fuse.
The Splice was done by stripping the wires and soldering them together. Insulated the splice with a heat shrink and then taped it. The splice is not the problem. I was hoping it was the problem, it would have been an easy fix.
OK on the splice. I looked at the wiring diagram for my 2013 and there are at least two 10A fuses indicated for TOW. these should be located in the fuse block in the passenger compartment. Have you checked that location for blown fuses?
You need to get a copy of the Service Manual for your model and locate how the wiring harness for the lights are routed, then inspect the harness at any 'exposed' location for damage.
There are a few sites that have pdf copies of the manual and you can also obtain a copy from Nissan Publications ($20 will allow you 24 hours access to the database which is amply time to download the pdf manual).
