1 - 8 of 8 Posts
I've searched but can't really find what I'm looking for.
I need all the info I can get about installing DT LT headers. Is there pics, vids, walk thru's... Specifically of the DT LT's.
I'm 2wd which should make it slightly easier.
I have someone who's very reputable and will install them for $50/hour. He said it shouldn't take him more than 8 hours at the most. He's never done a Titan before... But he's done a lot of others, including some V10's.
Is $300-$400 worth it to have someone install them? I understand with the DT's you need an engine hoist because it is mandatory that you lift the engine. Can someone confirm this?
you shouldn't need a hoist bud, im in the market as well but gunna go the shorty way, have a guy here thats guna help with the install save some money, but if you look up the headers like thru a dealer it should have a pdf file that will show instructions. the jbas do and the stillen ones also, so good luck.
Look at the similar threads listed on the bottom of the page.
Way down at the bottom.
Reactions: TiTAN- and Misfit
It is easier on the 2wd. You can jack the engine up on the base of the motor.
I got a quote from a local place...
$1,000 otd. That includes the LT headers, install, and everything that's required.
I think this is a fantastic deal. I can save some blood, sweat and tears.
Any opinions on the price?
That's basically the same price as your buddy. About $600 for the headers and $400 for the install. If you buddy is that good, on a 2wd, it should only take about 6-7 hrs. If you help, less time. Either way, you're spending about the same amount. Don't forget, you will need Uprev as well and that's another $500. Not to mention all the gas you will go through :D
There not that hard to install, save the installation $$$ for a tune :)
1 - 8 of 8 Posts
