I believe so...maybe 3"are you using 2.25" piping?
All I know is my Titan flew with my single bullet, now she's a slug. Duals give a much deeper grunt and rumble...WOT it sounds awesomeI was unaware we had high end torque!
An x pipe might help, but I'm no expert. How much louder are the duals compared to a single bullet?
Did you run an x-pipe? Sorry what's AFR?I just recently ran dual borlas. Before that I ran a Y pipe setup for over 1.5 years. I just wanted to see if the Titan really needed backpressure. To sum it up I ran slightly better on the track with true duals. I lost no low end or top end. It pulls actually a little harder up top now. I'm running 20" of pipe off the headers and then the borlas dumped. 2.25" pipe. Sounds like maybe your AFR went Rich to me.
Nope, half as loud as my single bullet. Ill get a vid soon.AFR means air/fuel ratio. Deer, isn't that a wee bit loud? Haha
Just disconnect positive and press brake then sit for 5 min? I'll try tomorrow. Thanks!What u have to do is disconnect the positive from the battery and press the brake which is optional to drain out the current and let it sit for maybe like 2-5 mins. I did it on my si, ridgeline, and now Titan when installing intake or exhaust to trick the ecu into thinking it's always been like that. When I changed my exhaust on my si, it felt loose but as soon as I did the battery trick it fixed it. It has something to do with the car starting out fresh which is quicker to having to relearn which takes some time and loss of performance.
Are you saying to disconnect while truck is running or off?What u have to do is disconnect the positive from the battery and press the brake which is optional to drain out the current and let it sit for maybe like 2-5 mins. I did it on my si, ridgeline, and now Titan when installing intake or exhaust to trick the ecu into thinking it's always been like that. When I changed my exhaust on my si, it felt loose but as soon as I did the battery trick it fixed it. It has something to do with the car starting out fresh which is quicker to having to relearn which takes some time and loss of performance.
No. Don't do that. Also this is the equivalent to unhooking negative cable over night. It clears learned fuel tables, looks to ECM for fuel maps which is being constructed by data from o2 and MAF sensors. In the long run it is still going to try and lean/richen you up to make the readings similar to stock.Are you saying to disconnect while truck is running or off?
Sent from my DROIDX using AutoGuide App
