needed that is easy enough to install in the overhead console in the back. I have a LE CC if that matters.
Thanks.
Are you wanting one of those all in one deals or to just put the monitor up there and the dvd player somewhere else?
Either.
I am sure it would be easier to change the DVD if it were separate, but at this point I am considering all options.
Titan_LE said:
Either.
Myron davis has direct replacement that will go right into the overhead console, with an external player. BBF has posted a pic before of someone who mounted one of the all in one units, but had to build a custom piece because it was too wide. Others have bought just a monitor and somehow made a trim bezel so it nice in the flip down compartment you have. I have not seen the closeups to tell you how it was done though. I think the myron would be the simplest though.
Check with tech12, I think he is a myron distributor.
