1 - 13 of 13 Posts
Is there a consolidated list of dyno pulls? If there isn't, is anyone interested in starting one?
I did my first pull with my Titan last week.
Baseline (stock)
282 rwhp
340 rwtq
There should be a database of time slips & dyno sheets! "HINT-HINT" TT ANDMIN. :)
Congrats!! Those are some good # for an '04! Can you post a pic of the dyno sheet? Do you have any performance mods?
This is a before and after my first two mods; Banks ME & CAI, with SAE correction applied. In my sig is the uncorrected (actual results based on the current weather conditions.
This was done on a drum dynojet, not a hub dyno.
The green lines are stock values which are close to your own.
Love to see a listing of these too!
I have unhooked, and packed away my scanner, but I will upload a phone pic of the dyno sheet tonight.
My dyno guy also runs a wide band O2 sensor in the tailpipe.and I notice my power falling off as my o2 goes from 14.7 to around 12.0. Is this typical?
Discussion Starter · #8 ·
DynoJet drum
Sent from my Fascinate using Autoguide
My #'s from the last Dyno Day @ Relentless RPM were 279HP/377TQ.
(that was with my T in 91oct Map) I forgot to switch it to 93 Track Map...:bangit:
Ill see if i can find the printout...
279HP/377TQ (91 Map) -No Cats, 2.25"-3" Y-Pipe
293HP/355TQ (93 Map) -No Cats, 3" Y-Pipe
This was before i had my exhaust re-done & installed the Berk Tech B-Pipes. Even though the 1 run was done in my 91map, you can see the difference in the where the power comes in due to the Y-Pipe swap.
Discussion Starter · #10 ·
gweasal,(everyone really)
What mods gave you those numbers? Did you get a baseline before any mods?
No i never got around to getting a base line, wish i would have though...
Both of these runs were done with the mods that are in my sig, minus the Berk Tech B-Pipes & Hi-Flow Cats. Also, in the 1st one i posted i had a 2.25" -3" Y-Pipe & in the 2nd. one i had a 3" Y-Pipe.
· Banned
Every car maker does this to their mass production vehicles. They tune it to run rich in the higher rpms, to cool combustion off and lose power so you don't feel like revving out that high. It's for longevity and safety. On my car it starts richening from 13'ish afr down to 12.5 around 7600 rpms, then by 8000 it's 12.2 and at the rev limiter of 8200 it's 11.9
It's done on purpose.
dyno numbers are in my sig
1 - 13 of 13 Posts
