Does anyone now where I can get a 2 degree timing Advance around the East Texas Area? Also there was a thread the other day showing a step by step on how to do the timing advance and now I cant find it if anyone knows where it is could you let me know.
Warm up vehicle.
On CONSULT 2 screen choose ENGINE
After communication with Convertor will display a bunch of choices.
Press WORK SUPPORT
See more choices, press TARGET IGN TIMING
Press UP x2 for 2 degrees, correction which you should be able to see.
Press UPDATE.
Now press BACK
On the menu screen find IDLE AIR VOL LEARN.
Press, and perform to correct your idle since you just raised it 75rpm with timing advance.
What "big city" are you near?
baseballfanz said:
Warm up vehicle.
Press WORK SUPPORT
Press UPDATE.
Now press BACK
Tyler Texas
I'm from Kilgore originally, lemme know if you find a place to do it cause I'll be over there in May. :gunz:
wilk3215 said:
Tyler Texas
baseballfanz said:
Man the closest that I know of is member LANDMAN and he's in Dallas. Maybe you can get with him at the next meet they have.:cheers:
Tyler is about 45minutes to an hour from Dallas... Not too far of a drive IMO
