Was not sure where to post this but I need some help... Well it all started when my battery died for no apparent reason and then when I replaced it my abs and slip light came on and wont go off... and now my 4x4 hi will only work when the truck is first started and before put into gear turn it on and then after I have been driving and want to use it I have to turn the truck off turn it to 4 hi turn the truck to on and let the little clicks then turn it on and 4hi is engauged... but the 4x4 light flashes so there is something wrong... the only way 4x4 works correctly is when the truck has been sitting for a bit and I do the turn on and put in 4x4 before I put into gear... anyone else had this problem?
hmm... where is that about? so I can check it out... also this would affect the 4x4 unit not engaging when the vehicle is turned on?
