So I just pulled my valve covers and upper timing covers to reseal them... Now it's in need of a serious cleaning, any ideas? Kinda skeptical about hosing off my engine with all them electrical connections... Anyone got any pointers? Tia
Jeremy
Purple power, super clean, or other degreaser. Hose down then spray cleaner then rinse. I personally wouldn't use a power washer...too much pressure will push water into connectors and other places you dont want water. Just my .02
Awesome I got purple power at home.. And Yeah I'm nervous just using regular water much less a pressure washer... Thanks for the quick response
Oh, make sure the engine isnt hot. Warm or cold is ok
Regular hose pressure is fine. Like a heavy rainfall, just take it easy with the jet stream. After you're done, start it up and take it for a drive to dry everything off.
Sent from my SAMSUNG-SM-G930A using Tapatalk
