Alright, guys, I've got a small problem with my 2011 CC Pro4X. I did an oil change and swapped the air filter a week ago, and since then, it's idling a little high and acting funny on downshifts. I've searched the forum and didn't find much to match my symptoms, so here's what's going on:
When I crank the engine, if it's cold, idle is high, like 1200-1300rpm. After it heats up, things normalize, so maybe that's not a real issue, but I don't recall it being so high in the past. What really bothers me is when I'm braking, as the truck now wants to rev itself 300-400rpm when I'm off the accelerator and foot on the brake. I've watched values in my Torque app, and what I see are two things which concern me. First, my short term fuel trims are all over the place (-8 or so up to 9 or 10) when I'm idling or just running along holding a low speed, like 35 or 45mph. Stick my foot in it, and it goes back to normal (-1.8 up to 2.4) and holds steady. Second, my throttle position sensor position jumps around, even when I'm not touching the accelerator pedal, from 2.5% up to 5.5-6% and back, with a corresponding increase in engine rpm. This is usually while coasting but does happen while sitting at idle.
Now, I think this could be one of three things. I could have a throttle position sensor out of spec, or I could have a vacuum leak (maybe from jostling the intake tube while wrestling the air filter cover back on the OEM box???), or I could have an idle air control valve going bad on me. What do y'all think?
I'm going to try to set up the TPS to relearn tomorrow morning, and see if that solves it. If it doesn't, I'll be headed over to the dealership (still just barely under the 5yr/60k powertrain warranty) but I'd rather avoid the dealership if I can, as it's inconvenient and they're not the sharpest tools in the shed.
Anxious to hear what y'all think might be wrong with my T.
