Well, there is not much to be said that has not already been brought up multiple times about the two individuals you deal with when getting Headers, Bpipes and a tune through Cajun.
Jeff with Cajun Bpipes is very prompt w/ information whether it is a question about what you should order, what to expect, how to do something or when parts will ship or are in transit. I felt he was above and beyond as far a getting things to me being as I ordered a week before they were put under biblical style rains. I have as of yesterday(3/26) just received the headers and plan to start the install in 2 weeks in hopes that the weather improves a bit as we are still having freezing temps and I will have to leave the garage door open from start to finish and I have many tropical plants I keep indoors during the winter.
Joe has also been equally helpful in giving info and steering me towards the info I need to get a grasp on the whole UpRev, Osiris, Cipher adventure as this will be the first time I have fumbled around w/ anything such as this(My motto: if it ain't carb and points I don't need to touch it).
As I have yet to install the headers, I have only hooked the computer up and played around w/ the whole setup. I figure I'll wait to make the "Earth shattering ka-boom till its all installed" then I'm sure he will probably feel harassed w/ my goofy questions as I can be a bit nervous with something like this.
As far as quality, the Bpipes look professional and well made. The JBA headers are not bad but I expected a bit better finish. I spent about 1 1/2 hours in the shed with files and a dremel cleaning up weld spatter and chamfering the plate to the pipes as they were extremely rough and misshapen. Taking a straight edge to the flanges, where they press against the gasket to the head, they are a bit out (6 thousands) but not enough that they can't be pulled to the heads easily. In the defense of all involved these are the lowest cost long tubes that he offered so a little bit of work to get them to perfection is not out of the question. As far as the welds on the headers they all look good and they seem very solid. When looking inside the pipe where the four pipes come together the welds are very nice and seem to be well done.
All in all I think that everything so far has been great with Jeff and Joe. I am now only hoping that the weather holds out so I can start the install.
I've been under the truck multiple times getting blocks cut wrenches bent and trying to check all my p's and q's to get everything ready for the install as I will not be able to let the truck sit as it is frequently used by my wife if I drive her gas getter to work and she does not drive the Ol' Ford(84 3/4 ton w/ 4speed & 460cid).
I have new O2 sensors from Walker that should reach the bungs further down the headers as well as some new studs and nuts for the headers in case of the obvious problems happening. Also, have the little things such as gaskets and anti-seeze. I also figure I'll put in a new air filter and plugs immediately after the install in order to get the best results for the data logs.
I again want to say thanks to Jeff and Joe as they have put much effort forward toward keeping me informed and ready for all the install has to dish at me.
I will try to keep tabs on the install so as to help anyone else be informed on ways that worked for me in installing the headers on a 4x4 titan.
