I have an 2013 Titan SV and it has a factory backup camera on tailgate. I'm looking to put an aftermarket Pioneer stereo in it. I don't want to lose backup camera or put in a new one. Is there a way to keep existing camera and just use its wiring? I have seen nothing about factory backup cameras anywhere so anything helps. Thanks!
What you need is a wiring harness: AX-NIS32SWC. You can also use this harness with the AXXESS steering wheel control module.
Thanks for response. So I purchased both items for vehicle even though the AX-NIS32SWC says on many sites it won't work for my vehicle, the harnesses fight perfect but I am not getting any response in reverse or changing to video. Have you used this item eakes?
I have a 2013 Titan SV that I installed a Pioneer HU in shortly after purchase. At that time the wiring adapter in question did not exist. I actually installed an aftermarket BU camera which works fine. Another member of this site mentioned he was going to use that wiring adapter. I purchased one (it's presently on my desk) and am planning on installing it later this summer (the other member has since stated that it works well on his titan). I also installed the SWC adapter - the only function that works is Vol up and down, but it works.
The BU camera function will work without the SWC module present. connect the battery (accessory),and ground lead to the radio harness. Connect the BU sense wire to the HU BU sense line and the video connector to the BU camera input. The HU needs to be set to turn on the BU function when voltage is present.
I don't know this for fact (haven't taken time to check) but I think the Nissan BlueTooth module is interfering with the SWC module causing only the Vol functions to work. I need to disconnect the BT module (under the passenger seat) to see if this is true.
Thanks for the assurance. I read your post and went back at it, come to find out I had it wired right but I had the video connector into the video out instead of video in and had to turn on the camera on Pioneer head unit (it was a long day of wiring and running amp cable). Works perfect now! Great harness. I am having issues with the SWC adapter as you are...It's flashing the way it is supposed to when programmed correctly but no buttons are working. I tried 5 or so times and nothing. I'll have to look more into that now. I'd hate to lose those their a nice function.
