artacus said:
Where can I find factory battery specs?( CCA, size, etc.) Looking to get either a Diehard or Optima battery but also looking at a Procomp super hdx.
Should be a sticker on top of your battery with CCA infos.
According to Nissan it's 27F. Well my battery went out on me this morning, I got the 24F that has higher CCA than the OEM battery. It's a tad bit shorter than the OEM. (All the 27F they had in stock had the post reverse).
Yeah my battery has no sticker therefore no clue what it is. I'm sure it is the original ( I bought my truck used) and it starting to leak a little bit out the vent caps. What is the recommended cca/ca?
I know the OEM BT battery was 710 CCA. So at least that or more would be good I guess.
I bought a Duralast Gold this morning, CCA 750, Cranking 935 and reserve 135, all rated higher than the OEM I had. I don't have stereo system or lights so it's good enough for me I guess.
I might be reviving this thread, but I was wondering what is the smallest that you could put into this without having issues?? I bought my titan from a used dealership and they claimed they changed the battery while it was owned by the previous owner, and from what I was reading an OEM is 710 CCA, correct?? well they put a 600 CCA in mine?!? and it has the towing package. The battery was only installed in 2012, but I notice it has to crank a couple times before it starts and when it does the gauge is low, but charges back up quickly. I also notice that while I drive the battery gauge is always moving from middle to more higher charge and back. I thought about getting it checked but I am concerned about the low CCA of the battery and the up coming winter....
