1 - 18 of 18 Posts
Someone here pointed me to the Factory Service Manuals at
Nissan Ttitan Factory Service Manuals
I am not sure if this has been done already, but I had trouble figuring out which chapter in the Factory Service Manual I needed to look at for information regarding a particular portion of my truck.
The chapter titles are cryptically abbreviated, and some are hard to decypher.
I took the time to translate the chapter titles for my 2015 Titan into plain English and sorted them two ways: first by chapter title and then by abbreviated file name:
Sorted by chapter title:
ACCELERATOR CONTROL SYSTEM = acc.pdf
AUDIO, VISUAL & NAVIGATION SYSTEM = av.pdf
AUTOMATIC DRIVE POSITIONER = adp.pdf
BODY CONTROL SYSTEM = bcs.pdf
BODY REPAIR = brm.pdf
BRAKE CONTROL SYSTEM = brc.pdf
BRAKE SYSTEM = br.pdf
CHARGING SYSTEM = chg.pdf
CRUISE CONTROL SYSTEM = ccs.pdf
DEFOGGER = def.pdf
DOOR LOCK AND KEY = dlk.pdf
DRIVELINE = dln.pdf
ENGINE CONTROL SYSTEM = ec.pdf
ENGINE COOLING SYSTEM = co.pdf
ENGINE LUBRICATION SYSTEM = lu.pdf
ENGINE MECHANICAL = em.pdf
EXHAUST SYSTEM = ex.pdf
EXTERIOR = ext.pdf
EXTERIOR LIGHTING SYSTEM = exl.pdf
FRONT AXLE = fax.pdf
FRONT SUSPENSION = fsu.pdf
FUEL SYSTEM = fl.pdf
GENERAL INFORMATION = gi.pdf
GLASS & WINDOW SYSTEM = gw.pdf
HEATER & AIR CONDITIONING CONTROL SYSTEM = hac.pdf
HEATER & AIR CONDITIONING SYSTEM = ha.pdf
HORN = hrn.pdf
INSTRUMENT PANEL = ip.pdf
INTERIOR = int.pdf
INTERIOR LIGHTING SYSTEM = inl.pdf
LAN SYSTEM = lan.pdf
MAINTENANCE = ma.pdf
METER, WARNING LAMP & INDICATOR = mwi.pdf
MIRRORS = mir.pdf
PARKING BRAKE SYSTEM = pb.pdf
POWER CONTROL SYSTEM = pcs.pdf
POWER OUTLET = pwo.pdf
POWER SUPPLY, GROUND & CIRCUIT ELEMENTS = pg.pdf
POWER WINDOW CONTROL SYSTEM = pwc.pdf
REAR AXLE = rax.pdf
REAR SUSPENSION = rsu.pdf
ROAD WHEELS & TIRES = wt.pdf
ROOF = rf.pdf
SEAT = se.pdf
SEAT BELT = sb.pdf
SECURITY CONTROL SYSTEM = sec.pdf
SRS AIRBAG = sr.pdf
SRS AIRBAG CONTROL SYSTEM = src.pdf
STARTING SYSTEM = str.pdf
STEERING SYSTEM = st.pdf
TRANSAXLE & TRANSMISSION = tm.pdf
VENTILATION SYSTEM = vtl.pdf
WARNING CHIME SYSTEM = wcs.pdf
WIPER & WASHER = ww.pdf
Sorted by abbreviated file name:
acc.pdf = ACCELERATOR CONTROL SYSTEM
adp.pdf = AUTOMATIC DRIVE POSITIONER
av.pdf = AUDIO, VISUAL & NAVIGATION SYSTEM
bcs.pdf = BODY CONTROL SYSTEM
br.pdf = BRAKE SYSTEM
brc.pdf = BRAKE CONTROL SYSTEM
brm.pdf = BODY REPAIR
ccs.pdf = CRUISE CONTROL SYSTEM
chg.pdf = CHARGING SYSTEM
co.pdf = ENGINE COOLING SYSTEM
def.pdf = DEFOGGER
dlk.pdf = DOOR LOCK AND KEY
dln.pdf = DRIVELINE
ec.pdf = ENGINE CONTROL SYSTEM
em.pdf = ENGINE MECHANICAL
ex.pdf = EXHAUST SYSTEM
exl.pdf = EXTERIOR LIGHTING SYSTEM
ext.pdf = EXTERIOR
fax.pdf = FRONT AXLE
fl.pdf = FUEL SYSTEM
fsu.pdf = FRONT SUSPENSION
gi.pdf = GENERAL INFORMATION
gw.pdf = GLASS & WINDOW SYSTEM
ha.pdf = HEATER & AIR CONDITIONING SYSTEM
hac.pdf = HEATER & AIR CONDITIONING CONTROL SYSTEM
hrn.pdf = HORN
inl.pdf = INTERIOR LIGHTING SYSTEM
int.pdf = INTERIOR
ip.pdf = INSTRUMENT PANEL
lan.pdf = LAN SYSTEM
lu.pdf = ENGINE LUBRICATION SYSTEM
ma.pdf = MAINTENANCE
mir.pdf = MIRRORS
mwi.pdf = METER, WARNING LAMP & INDICATOR
pb.pdf = PARKING BRAKE SYSTEM
pcs.pdf = POWER CONTROL SYSTEM
pg.pdf = POWER SUPPLY, GROUND & CIRCUIT ELEMENTS
pwc.pdf = POWER WINDOW CONTROL SYSTEM
pwo.pdf = POWER OUTLET
rax.pdf = REAR AXLE
rf.pdf = ROOF
rsu.pdf = REAR SUSPENSION
sb.pdf = SEAT BELT
se.pdf = SEAT
sec.pdf = SECURITY CONTROL SYSTEM
sr.pdf = SRS AIRBAG
src.pdf = SRS AIRBAG CONTROL SYSTEM
st.pdf = STEERING SYSTEM
str.pdf = STARTING SYSTEM
tm.pdf = TRANSAXLE & TRANSMISSION
vtl.pdf = VENTILATION SYSTEM
wcs.pdf = WARNING CHIME SYSTEM
wt.pdf = ROAD WHEELS & TIRES
ww.pdf = WIPER & WASHER
Let me know if I messed up any of the names.
Thanks.
NRA_Guy, I may be the one who pointed you there... so I just looked at the 2015 directory, and it also doesn't have the fwd.pdf "Foreword" file that the 2014 Service Manual does (which is my first stop, since it has a hyper-linked table of contents). Pretty weird that file doesn't exist in the 2015 directory. There can't be too may differences between the 2014 and 2015 manuals, so if you get stuck, just pop over to the 2014 directory, go to the FWD.pdf file, and you can probably triangulate on what you are looking for.
And, thanks for the translation!
Cheers!
Reactions: NRA_guy
From the NICO Club web site:
In March 2018, Nissan North America (NNA) served notice upon NICOclub that the documents contained herein infringe upon the intellectual property rights of Nissan and demanded we immediately disable access to the contents of Nissan Service Manuals and Infiniti Service Manuals:
The site no longer supplies literature on vehicles.
I purchased the 2017 Titan Nissan Factory Service Manuals with wiring diagrams on 2 CDs. $285.00. Search on Google for Factory Repair Manuals and you can find a source. They are the real manuals on CDs from Nissan North America. Took about 10 days to get the CDs as Nissan was a special order.
you used to be able to pay for a one day subscription to their tech-info page, for like $10, and simply start downloading. I did this and downloaded several models over the time period allowed. i think it was 24 hours. I believe they have changed this, and do not allow downloading anymore, but you might want to check it out.
They don't have the 16+ Titan on that page to download even with the subscription. I really wasn't wanting to spend the 285 to buy the cd's. Was hoping someone on here had a copy of them they would be willing to share.
1 - 18 of 18 Posts
