Go BIlstein HD
Thanks for the recommendation but can you tell me why you recommend the HDs?Go BIlstein HD
Decent price, and people say they are day and night difference from stock.Thanks for the recommendation but can you tell me why you recommend the HDs?
The main question is what are you planning to do off road? Pre-running or just some extra beef on the truck if you decide to hit some trails on the weekend?Will I need to do anything else to make it more offroad friendly?
Just extra beef for hunting seasonThe main question is what are you planning to do off road? Pre-running or just some extra beef on the truck if you decide to hit some trails on the weekend?
Will the 5100s lift it more with my PRG mini lift on?My Bilstein HDs made my truck much more comfortable to drive....even with a 6 inch lift it is riding much better than stock. The ride is smooth. You indicated that you didn't want more lift which the HDs will not add. I believe the BIlstein 5100 series will add about 1/2" of lift on the lowest setting.
Thanks for your help Mattastic13. Can anybody else help answer this question?From what I know, the 5100s have several settings from I think 1/2" at the lowest to maybe 1 1/2". So yes it will lift it more. But I don't know if it will cause coil bucket contact. Someone with more knowledge than I will have to answer that.
