1 - 14 of 14 Posts
I figured out a way to fix my no low beams issue, after a couple weeks of trial and error, new switch, relays, etc, I came to the conclusion that it was the IPDM that had malfunctioned (noticed this happened in quite a few Titans), but the point it I figured out how to make them work correctly without spending $300+ on the new IPDM board. Took half an hour tops. If anyone needs this fix or has questions just message me, I know I had been cratching my head for months trying to find a way to fix this and haven't found any resolution to this issue on any forum besides swapping out for the new upgraded IPDM. Electronics Technology Electronic device Electronic component Circuit component
Sent from my SCH-I545 using Tapatalk
Why not post the problem and the solution here, so that others may benefit from the knowledge? This is an open community. We all try to help when we can. That's the best thing about forums. :nerd:
Just ran a wire from the red wire running to the right high beam and connected it to into the IPDM. Low beams come on with switch in the parking light position and in the normal low beam position as well, but also they stay on when switched to high beam. Who ever had this truck before me did that wiring and it had just came off and I didn't know neither of that until until I was searching for what could be wrong. When doing the IPDM test the low beam relay still clicks but don't come on? Is that a ground issue or just an issue with the IPDM ? I'd like to repair it fact to factory working order because I'm not sure if it would burn anything up while in the high beam position since both sets of headlights are on
My money says, since I've owned a T for five years, been active on this forum about that same time, and have never heard of any "low beam issue" your issue is likely related to the prior owner's rewiring job and not anything to do with the Titan.
I had the low beam issue as well and had a new IPDM installed to correct it. Nissan Mech said it was common, replacement part had been updated.
Well I have to wait for Nissan to refund my last order, I went on the Nissan part site and ordered the IPDM that was supposed to be the preceded correct number. But Nissan tech emailed me saying it was discontinued and I had to order a new one that was $150 more
I figured out a way to fix my no low beams issue, after a couple weeks of trial and error, new switch, relays, etc, I came to the conclusion that it was the IPDM that had malfunctioned (noticed this happened in quite a few Titans), but the point it I figured out how to make them work correctly without spending $300+ on the new IPDM board. Took half an hour tops. If anyone needs this fix or has questions just message me, I know I had been cratching my head for months trying to find a way to fix this and haven't found any resolution to this issue on any forum besides swapping out for the new upgraded IPDM. View attachment 422921
Do u have a picture of how it looks I’m going through this now
I could use some help. I have an Armada and have already replaced the IPDM and the low beams are STILL not working.
Can you send wire
Hello I’m having the same problem on my 2017 Titan can you please send me the fix for low beams not working. [email protected]
1 - 14 of 14 Posts
