Here are some pix.
I used street edge 2/4 drop, bilstein in the back, bell tech adjustable up front. Bell tech set to lower 1".
Total drop 3/4.
Pro:
I like the drop.
Con:
Soft.
When bell tech goes bad up front then I will use bilsteins.
Was bouncy. Removed bump stops which fixed bounciness. Still soft though.
Tires are a bit thin (135/55) and will get larger once they wear out.
do you know the specs on those Street edge springs? Are they constant rate or progressive rate? How are the street manners? cornering & bumps? height looks perfect....
Hi Armada06,
I do not know the specs. I should have asked them before I purchased. The ride as a whole is soft. Bumps are okay, after I removed "bump stops". Cornering....none since it as a whole it is soft. The stock felt stiffer.
You can call street edge and ask. I am curious as well.
Dude that is bad a$$. most posts have guys going the other way!. I dig it. I would get a little taller and wider tires, to make your stance that much more bad a$$. One day, I'll lower mine like that but just drop shackles to level the rear will do for now.
Did you do a spring under mod or just different spring packs?
Hi Danman,
Ya, I will def get wider and taller tires. The guy at the shop when I bought the rims only had those size tires. LOL. So once they wear out, wider and taller tires we go.
I have street edge springs and leaf. I DO NOT Recommend street edge.
Ya, another way I could have gone and maybe I should have gone is flip kit drop shackles and name brand springs.
