** Just realized you cannot edit the title... should be more like JBA Headers/Cajun/upgrev lol but whatever
Well I finally got my axle fixed... Time to start the full exhaust install.
Yesterday I got started on the drivers side of things.
I removed the wheel, then plastic liner to access heat shields. got them off fairly easy. Soaked all the manifold bolts in PB Blaster, then fired the truck up and warmed it for 10-15 minutes letting it idle.
I moved on to the end of the exhaust and found that where the tail pipe broke, my wire harness was about as close as it gets to being burnt up! I fixed it by wrapping it up with some electrical tape... What a close call!! (see pic)
I was able to get all 3 of 4 bolts removed from the B-pipes, one will need cut. Most of the rest of the exhaust will need cut out as well, the bolts are extremely rusted and just round right off. I got the secondary 02 sensors out.
I sprayed the manifold nuts again with PB blaster, then started the truck and let it run for another 10-15 minutes, then shut it down. Is this the correct procedure or is it not necessary to do this heat cycle?
This afternoon at lunch, I figured I'd have quick go at 1 of the manifold bolts, the one I could get to easiest. It will not budge! This makes me pretty nervous... I have the wife picking up a $15 can of Aerokroil hoping for the best.... Is it ok to use the air gun on the manifold nuts or is the preferred method a breaker bar?
Weather moron is calling for thunderstorms tonight, but if I get lucky and no rain, my plan is to cut off the rest of the exhaust where needed and get everything removed accept the manifolds. I still have to get the passenger side up on a jack stand and remove the plastic wheel liner and then heat shield so I can start soaking those manifold nuts as well. Since it seems to take most people 8 hours for this install, I'm guessing mine will be around the 16-24 mark.. That's just how it goes anytime I work on anything!
