One of my few criticisms of this truck is how softly sprung it is. Even with my Equalizer hitch the rear still sags a good bit towing my racecar.
I had air springs on my old GMC Canyon and really didn't think I'd need to add them to the Titan. Briefly considered an add-a-leaf, but I like the versatility and adjustability of the bags. It was between the Firestone setup or Airlfit (had Airlift on the Canyon). The Firestone won out as they're more robust, can provide up to 5000lbs of support (vs. only 2000 for the Airlift) and are a bolt-in install vs. drill.
The hardest part of all of this was figuring out how to fish the nut-on-a-stick into the frame at the correct angle to get the upper bracket bolted in place. I was able to run the air valves in place of the license plate screws for a very clean install.
-Brian
-Brian
