Just FYI... When we are discussing Up/Rev terminology the ROM file is what is downloaded into the ECU & the maps are what you choose between with the CC buttons. I don't want anyone getting confused...
If you used the CC to set the tune into Map1 & saw the SET light flash on the right side of the cluster, then more than likely you forgot to add "WOT enabled" in the details of the order form. Send Up/Rev an email stating what happened & i'm sure they will re-write the tune for you.
The first day i got my Up/Rev installed on the T i went out to a stretch of road for testing, i forgot to take it out of stock map. LMAO! I thought i'd been had too for a minute, till it figured out!
There's just no way that you could not notice a difference... When you floor it from a stop the right rear tire should start screaming! LOLyea after i posted this I found it. I am worried I just threw $500 in the water. No power gain sofar. ill log some data and see what is to do.
