Hi all, im new to the fourm here and am lookin at gettin me a Titan. Im a Diesel Mechanic by tradeand own a 93 dodge cummins with an extensive list of mods. I just recently drove an 05 extended cab Titan (not four door) and really like the ride and it has decent power for only having a CAI. I dont have alotta expierence modding gas rigs, especially ones with a computer controlled fueling system. I was wondering (and yes i have used the search function) what it takes to turbocharge (not supercharge) a computer controlled gasoline engine.
As far as i can tell, since a diesel is basically a big air pump that you add fuel into, a gas engine must be a fuel pump you add air to correct? So being that, wouldnt i need to put larger injectors, and maybe a chip to raise rpms and also the amount of fuel injected? Also, i bieleve i would need heavier valve springs (possibly valves?) and of course head studs to accomidate the higher cylinder pressure.
I plan on using an H1C. (one step smaller then an hx35). Also what kinna boost numbers would i be showing (plan on installing egt and boost gauge.)
Thanks in advance
Pitman
Thanks in advance
Pitman
