Purchased this truck (04 Big Tow 4x4) to pull my boat with one week ago. Today was the first time I had a chance to hook the boat up and give it a test pull. I pulled to the ramp just a few miles from the house. Launched the boat and pulled it back out with no issues. Did not have to use four-wheel drive. I'm not sure of the tongue weight but it definitely sagged the *** end of the truck. My question is what would be the best solution to not have the truck sag so much? Air bags, different springs or shocks?
Dang, that's a lot of boat. They have the engine over the trailer wheels and everything else on the tongue. I think a trip to the scales at a local truck stop is in order.
If the weight isn't over the limit, a good set of airbags will be a great help. They added a lot of stability to my truck. I'm afraid that the tongue weight is gonna be very high on that setup.
Rated tongue weight is no more than 940 lbs, assuming you have the tow package and other options.
I towed my 11K RV trailer with a tongue weight close to 1,000 lbs and I broke the leaf spring bracket that is attached to the frame. The leaf spring shackle was also damaged.
Air bags might help, but you're still over the rating. The hitch is rated for 940 lbs only when used with a weight distributing hitch.
After looking around and doing some research. It looks like I'll have to invest about $800 for what I'll need to make a WDH work with my boat trailer.
So I think I can move the boat back enough to get the tounge weight down around 700 lbs and go the air bag route.
Moved the boat back almost 2'.
Tounge weight is down to 600 lbs.
Which I'm guessing is at about 9% of the total boat and trailer weight (7000lb est).
Truck sits nice and level now.
So I have a 2015 sv. I saw the hitch weight is for 930lbs. I'm looking at a camper it's a 2005 fleetwood scorpion s1 toy hauler with the pop up in the front. The weight says the hitch weight is 980. Would a weight distribution system help so I could pull this unit. Looking for advice
Well, just thought that I would ask for people to post some pics of their truck towing. What do you tow???? Any problems towing??? I am potentially going to be a new titan owner in a month or two. I just havent decided the trim or color. I was at the dealer today and the locate turned up nothing...
Can a winch be mounted on the track behind the cab for purposes of dragging big game up into the bed? How much weight are those tracks rated for? And is there a specific mount for such a setup?
